Things you see but cant believe!! | Page 3 | on ElectriciansForums
Discuss Things you see but cant believe!! in the Australia area at ElectriciansForums.net
C
chiplard
Can you spot the work of an idiot.
Reminds me of the typical quality of a early 1980's barrats house, both phase and neutral from the 60A switch fuse to the consumer unit were wired in red.. The temporary fix when I discovered it was to check polarity and then use some black tape...
Mind you...been at the "joint box" house today (as we have christened it)...lol.....i think at the last count we have had about 20 odd out of there.....a poor install by any standards..........
Where’s the reversed polarity?
Hello
Not sure if covered already but to me, the tail supplying the visible LHS of the main isolator on the old wylex board is....brown...? There are black cables to it's left and it looks brown (tail) to me. I also am assuming the LHS of the DP iso feeds the neutral bar-can't be sure from memory but makes sense.
That's where I see it but am always ready to take a good cuffing for being wrong....
Reply to Things you see but cant believe!! in the Australia area at ElectriciansForums.net
PVA V PRIMERS – WHy you should never use PVA Glue when Wall Tiling PVA V PRIMERS – WHy you should never use PVA Glue when Wall Tiling Don’t...
That'd be a great help mate. You could attempt to use chat gpt. Instruct it to rewrite the following and paste the lot in and 50% of the time it's...
