Guest viewing limit reached
What a joke!
Surely there should be something in place so that if a unsatisfactory is issued then building control are notified and then follow it up to make sure it gets rectified and re tested and a Satisfactory issued upon completion of rectifications!
That would be far too simple I guess! ;-)
I contacted Elecsa regarding this yesterday and they said its still in the process of discussion and nothing is finalised, I said well thats about as clear as mud when it comes into force with the new part P requirements on the 6th APRIL
I said will this mean i could effectively sign someone elses work off and notify through the scheme
They said you can sign it off but wouldnt be able to notify through my registration so were do you notify it lol
and do the designers , Installers sign jsut for that and I sign a EIC for I&T
or will it be like now were basically you cant sign an EIC for someone elses work only carry out an EICR
So the DIYer is supposed to be able to design , Install and I&T so have calibrated test equipment etc complete a certificate and then get us in to carry out another I&T for the EICR
WHAT A COMPLETE CROCK OF ????
second question to elecsa was regarding the register and why ELECSA approved contractors are only shown as DI status when they may be carrying out all types of work But the NICEIC are shown as approved contractors so this may have a resulting effect of undermining the type of work an ELECSA approved contractor gets
3rd and final Question
when applying to JIB for GOLD card and QS status a ELECSA registered eneterprise has to show a registratation and certifcate for the assessment that has to be dated within last 3 months BUT Napit and NIC are allowed to send one in thats dated in last 12 months ??
answer so if a contractor was 11 months into registration applying for gold card with QS status but then either failed or left the scheme they couldnt get the status
STILL didnt answer my question why the difference between elecsa contractors and the others when all are supposed to be equal in there requirements of competence
I thought ELECSA were the best of all schemes but recent changes like joining NIC and all this malarky is changing my mind.:dizzy2::icon13::behead:
I've just seen a HUGE flaw in this new 3rd party certification...see 3.7...
building control only needs to be notified once a satisfactory report has been issued.
So DIY Dave does his hatchet job, Pro Pete comes to I&T, fails it and goes away.
Dave doesn't give a whathaveyou, BC never hear about it...
Hahahahaha....what a complete utter farce. And people get paid vasts amount of money to generate this :censored:
so that is condoning undesigned work done by anyone, anywhere, unsupervised, and never needs notifying
schemes- what are they for again?
At present someone that does DIY work cannot get it checked easily, so often just hide the fact that the work has been done. Or designs the work in a way so as to avoid Part P, e.g. adding lots of sockets to a current ring rather than putting in a new ring.
I would expect someone like “DIY Dave” to keep doing what they have always been doing and not give a whathaveyou, so not get anyone in to check the work regardless of the regs.
However I think the much bigger issue are people being charged for sub-standard work by kitchen fitters etc and believing they have had a good job done. Personally I would like to all work that have been charged for (directly or as part of another job) having to be notified.
Thats the point though all this cobblers is just tinkering with a flawed and annoying system that simply benefits a middle layer by lining their pockets at our expense and the destroys the reputation of our industry.
there is, and always was, a simple answer.
make electrical work to be done by registered sparkys mandatory and not just regulatory
have one governing body that is non profit making and is there for the good of all
make it an offence to sell electrical goods to anyone other than a registered spark,
What was so difficult to do there? :-)
So simple to do yet will never happy! If bloody only!
What was so difficult to do there? :-)[/QUOTE]
I agree with most of what you say.
There will be one distinct and important change in April though, and that is the "perceived" legitimacy of carrying out electrical work by non-electricians. Of course there has always been, and always will be your DIY'er/builder/plumber etc who will do it anyway, but the new "do it and get it checked" system will say to everyone that an electrician isn't really needed for anything except testing. What a message to send out!
which bears as much relevance to this thread as a hairbrush to bobby charlton.
I don't think anyone without the ability to test and having the equipment should be allowed to do electrics.I recently had a simple job to replace a light pendant.No Zs reading and no Zs anywhere upstairs so now I am going to have to sort that out.Turns out possibly the builders did the electrics in a bathroom refurbishment and I bet they don't even know what Zs is.
EXACTLY!!!
which is why people shouldnt be bodging their houses either!!!!
EXACTLY!!!
Hum.... DIYers bodging their own homes is one thing, but builders, kitchen fitters, plumbers, et al charging unsuspecting people and doing bad stuff is the issue I think
Job I did earlier in the year which included 2 new CU's in a property. Tested R1+R2 at each metal light fitting, but nothing at a few of them. The owner had installed several aluminium fittings throughout the house the previous year and diligently connected all cpc's as instructed. Turned out to be a JB under the floorboards with external cpc's in ceramic block...several had popped out, hence no cpc continuity.
No way he could know, as no testing had been done.
Third party Part P inspections
ringi,
Guitarist,
