This old chestnut | Page 2 | on ElectriciansForums
Discuss This old chestnut in the Australia area at ElectriciansForums.net
O
Octopus
OK, here we go again.
Part built outbuilding, builder no longer around, electrics mainly first fixed - what do LABC's around the country "demand" from someone wanting to do the 2nd fix/completion??
Customer keen to do the right thing?
Wow Murdoch mate can't ask the owner for this sparks name can you?
I have this ring final on a 63amp MCB, done in 0.75mm flex, I tried to put it on a 32amp as you should but the welding machines kept tripping it, so therefore a 63amp, anyways it's sound mate the flex is lovely and pliable and holding well, but just need someone to sign off an EIC for me, this sparks sounds like the man for the job.
Its not too far from me so the odd drive past will probably do - mind you what can I do then?
Reply to This old chestnut in the Australia area at ElectriciansForums.net
Sockets will probably be ok on one, a little inconvenient in the event of a fault though, I'd probably like a 7th rcbo in. Wonder if hes linked...
8K
suffolkspark
J
Riven Slate: use sand/cement or adhesive - is there a definitive answer Hi - my builders bedded 10-12 mm brazilian riven slate on a sand cement...
Jim Rickards
J
