Those lovely plumbers | Page 4 | on ElectriciansForums
Discuss Those lovely plumbers in the Australia area at ElectriciansForums.net
sparkinlee
I've done first fix on a house rewire, and am followed by the plumbers putting in a completely new central heating system. I go upstairs to find, under the landing floor:
A whole bundle of cables sandwiched between heating flow and return pipes!
I've put foam insulation on the pipes to try to protect the cables from the direct heat, but do I need to insist the plumber adjusts the pipes? I don't fancy pulling the cables out to re-route - one of them I'm sure is the upstairs lighting feed continuous from CU downstairs to loft!
Tell him he's a "very naughty boy and would be advised to sort it out", or words to that effect.
To quote from kevin b100dy wilson,
"how hard is it to be a plumber - poo floats downstream, pay day's thursday "
Reply to Those lovely plumbers in the Australia area at ElectriciansForums.net
M
Cold Water Tank In Loft - Cause Of Flood Dispute? Having just moved into a property and discovering the central heating not functioning, after 3...
Mijacmad
M
