Thoughts on recommendation | Page 3 | on ElectriciansForums
Discuss Thoughts on recommendation in the UK Electrical Forum area at ElectriciansForums.net
Livingston
Had a call out from an estate agents I do work for, seen this and recommended to the agent it was addressed, and possibly an Eicr carried out as who knows what the rest of the property could be like! I don't know what its feeding as was late at night and only there to address a faulty cooker hood!
[ElectriciansForums.net] Thoughts on recommendation
The OP already knows it over 3meters if your going on about section 433 & 434. Further investigation is required but what would you code it based on that alone?
As I have posted links too FI really shouldnt be used unless a last resort (eg where supplies cant be switched off, unable to trace cable etc) seeing as no investigation or EICR has been carried out there no point trying to make it seem worse than it currently is.
Out of curiosity, what would you tell a landlord if you came across this situation?
No code if there is a fuse before any fixed wire equipment is installed.
What difference is there between this situation and a busbar chamber?
A busbar chamber should have a main switch between it and the incoming supply. A supply connected to the live side of the main switch in an installation not under the control of skilled etc persons is potentially dangerous as an unskilled person could open the main switch and reasonably expect the entire installation to be dead.
Where cables are installed with downstream protection (such as the busbar setup) they should be provided with mechanical protection and installed in such a way that damage/faults are least likely to occur. There is also a 3m suggested limit on such cables.
We are looking at a picture, the OP has given a very brief description of whatnhe has seen. How can everyone all pf a sudden claims it a C2 by that?
I am just trying to point out that there are regs that may allow it to comply. No ome is right or wrong at the minute, and until a "proper" EICR or a thorough investigation into what the cable does we wont actually know.
As far as I'm aware from reading this thread nobody has carried out an EICR or applied any coding, merely that if the worst case scenario is correct then a code 2 might be applied if an EICR is carried out!
Read posts #5 and #6, both have said they would give it a C2.
OK guys it was me - I first mentioned the EICR on the thread, so for clarity I should probably have written:
If I found this on an EICR and was unable, under the time allocated to doing the EICR, be unable to locate the "load" on the T&E connected directly to the isolation switch I would give it a C2 and and advise further investigation. :bigcry:
Lol.....
Great point here as well........
Reply to Thoughts on recommendation in the UK Electrical Forum area at ElectriciansForums.net
I usually put something like this To assess compliance with BS7671 for continued safe operation (5 year periodical inspection)
Thanks for the reply littlespark. Yes the works have been carried out. Surely it is fraudulent because basically the document is Not...
