were would you use a time delay rcd and what are the benefits of doing so is it just in tt installations
If you are installing a socket-outlet to be used for mobile equipment outdoors, then the socket-outlet will require 30mA RCD protection.
The problem you have with installing a time delayed up front RCD, is what delay you will use.
1s for distribution circuits, or 0.2s for final circuits?
Thanks Engineer 54 , i had never heard of the x3 recommendation .
That's because for RCDs it doesn't happen. As Eng 54 has said.
I rather think the x3 refers to discrimination of fuses, mcbs etc.
Lets say you have a 300mA RCD main switch(non time delayed) and sockets protected by a 30mA RCD.
Which RCD will trip first if there's a big earth fault on one of the sockets of more than 300mA? Its the RCD with the faster (time) trip characteristic or it may depend on where the AC sine wave is at. It could really be either, or - sometimes - both of them.
An S-type is the only way to ensure discrimination of RCDs.
Also there would be no need to use a 100mA rcd main switch if all circuits had 30mA Rcbo's would there?
But you are correct, for a domestic TT all RCBO there is no need for additional 100mA RCD incomer.Also there would be no need to use a 100mA rcd main switch if all circuits had 30mA Rcbo's would there?
Just a normal DP main switch.
i thought you needed the 100ma as main switch if the cu was metal.that seems the norm on the ones ive seenBut you are correct, for a domestic TT all RCBO there is no need for additional 100mA RCD incomer.
