Time for a new R2 lead | Page 2 | on ElectriciansForums
Discuss Time for a new R2 lead in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Just bought what looks like a Martindale R2 lead off e-bay for a remarkable £15.00 + £5.00 postage, sound too good to be true, will see soon I hope.
As I said above I have pushed the button on a second hand R2 Wander lead that looks like a Martindale, same embossed writing on the case and what looks like the same cable ends, I will have to wait until it arrives to verify whether it is a Martindale, but at £20.00 with postage not a lot to loose.
On the contrary, there is hopefully around 50m of it to loose. Just don't lose it!
looking at a lot of the branded ones, the actual plastic body is in many cases identical so i suspect they are made in some factgory and just badged accordingly. that said i have a kewtech one, 50m and does alright.
If you have the time and patience, get yourself a cable reel and make your own
then some cable and get the adaptors for the cable at each end off flea bay and you are good to go. will have change out of £40 i reckon.
cpc do an empty reel. easy to add 50m of silicon single and 4mm plug/socket.
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
Silicone cable in 4mm at 50M would cost about £100.00 unless you can find something at a better price, then I will try not to looooose it.
Well it's arrived and it is a Martindale, just carried out a continuity and insulation test on it and it check's out, very pleased for £20.00 bargaaaaaaaain
Reply to Time for a new R2 lead in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
First time doing a patio Hi guys, had some great advice here before so thought I would ask here for advice again regarding porcelain patio...
Sean-tries-to-tile
I am living in the north of Thailand where the grid is very unreliable (rainy season outages multiple times per week or once a full week). I...
