Hi jackall. As mentioned above, its hard to sort out the problem without some form of test gear.
Also maybe better if you get the post shifted to the DIY section, you may get less stick.
OK, I'll try to do it now...
Discuss Timer for outdoor lights not working in the DIY Electrical Advice area at ElectriciansForums.net
The Mods will have to move it. (We are the mods, we are the mods, we are, we are, we are the mods!)...
Their at Vespa's at the moments
Hello.
[FONT=&]Any ideas as to why the following timer doesn't work - the dial doesn't turn at all. There is an electricity supply going into the box because the last switch is for the boiler which works. The first switch is labelled 'General'; the next switch and the timer are labelled 'Outdoor lights'; and the last switch is labelled 'Boiler', which definitely works. All the wiring is attached and not loose at all.
[/FONT]
What of there are two feed to the time clock? One for the time clock and one for the lights? How would that be diagnosed by your description?
How can anyone tell from that photo how many feed there are in that enclosure?
Looking closely at the photograph ... I see 11 wires entering from above and 6 from below.
From above, LtoR:
- Brown
- 2 x Grey
- 1 x Blue
- 1 x Orangey Red
- 1 x Black
- 2 x White
- 2 x Blue
- 1 x Green and Yellow - CPC?
From below, LtoR:
- 1 x White
- 1 x Black
- 1 x Blue
- 1 x White
- 1 x Blue
Reply to Timer for outdoor lights not working in the DIY Electrical Advice area at ElectriciansForums.net
