Tips for cutting a 4'' hole through single pane window | Page 2 | on ElectriciansForums
Discuss Tips for cutting a 4'' hole through single pane window in the UK Electrical Forum area at ElectriciansForums.net
W
Will Mcloughlin
Ok, so any tips on cutting a 4 inch hole through a single pane window??
Buy a diamond tip Blade, Hole cutter?
Hire / Buy?
Cheers Will
I cut about 6 1 inch holes in a fish tank once and a couple of 3" holes in another, sounds bad but I used a dremel and a stone grinding bit thing on the end with the hose pipe on it. Gave me a perfect hole with smooth edges.
Finally,i have a name to give crimewatch regarding those un-solved guppy thefts at Pets-at-home.....
Reply to Tips for cutting a 4'' hole through single pane window in the UK Electrical Forum area at ElectriciansForums.net
Also good for cutting strands of cable armour, although I try to restrict their use to copper.
nicebutdim
N
