Tips for pulling 2.5mm T&E under galvanised metal capping | on ElectriciansForums
Discuss Tips for pulling 2.5mm T&E under galvanised metal capping in the UK Electrical Forum area at ElectriciansForums.net
uk
I have a two metre length of 2.5mm T&E running from the loft to a spur under galvanised metal capping (installed during building). Its needs replacing with some new cable ( long story).
As the cable is buggered, I decided to see how much force it would take to budge it, and it appears to be around three elephants worth. I really don't want to remove plaster and capping, refit etc.
Tips would be welcome !
If it's that difficult to get out then you may well find it impossible to feed a new length through anyway.
It is either going to work or it isn't have you tried from both ends. Uneven brickwork, the capping not being a continuous length can all hinder it.
Yeah, tried both ends, its tighter than a ... well lets say its not budging. The capping I have seen is really well fitted on a very straight bit of wall (concrete blocks) under plaster of equal thickness across the whole wall. Hats of to the plasterer, bloody impressive !
Cable may have grown since being fitted, expansion due to diet, who knows.
If you can't yank it out then you will have little chance pulling a fresh cable down it
Get the 4 inch bolster out and club hammer , time to mash off the plaster and see whats under neath
Remember to post a photo once you have mashed off all the plaster
A lot of the time mortar can make it's way into the channels from the bottom of the channel, and the very top, I've seen it mounded up at both points before now.
Normally I'll knock this out with a scutching chisel and most of the time the channel is clear.
Though locating the channel at mid point can also be useful if they still don't move, the channel may be free either way (up/down) and it can save a lot of chasing out.
Reply to Tips for pulling 2.5mm T&E under galvanised metal capping in the UK Electrical Forum area at ElectriciansForums.net
