TL4000 high pitched whining | Page 3 | on ElectriciansForums
Discuss TL4000 high pitched whining in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
done 24kw today - does that sound good?
I'm a bit over 23kWh today as of the last time I looked about 6pm. Being SE-facing (therefore the sun is behind my panels and I don't generate much in the afternoons), I'll probably only get up to about 24kWh by dusk.
System is 3.75kWp with 3.6 inverter as mentioned earlier. Been quite hazy sunshine, although no clouds at all today.
26.4kwh today. Peak only 3.2kw with 3.75kw Sanyo /sma 4000tl combo. South Coast, South facing and 23 degree pitch. The hot weather has definitely decreased production. Managed 28.7kwh in the cooler beginning of the month.
Nope! There's a whole load of things it "could" be but they are all highly unlikely - cables, connections, isolators. It's much more likely imho to be the inverter itself or the location. Is it tightly fixed to a solid wall with plenty of ventilation? You're not using it to keep your coffee warm when you work at your desk, are you!?! By switching the inverters, you've ruled out the possibility of a foreign object dropping inside.
I'm taking a risk here of being shot down, but here's a snap of one we did a while back in a loft. Notice the space for ventilation all around it. View attachment 11962
How does yours compare? This photo was taken before commissioning hence no warning labels etc.
Our customer's system is performing very well and we've not had any reports of noise although it is some distance away from the main living area.
Best plan might be to ask your installer to swap it for another brand and come to some deal on the difference in price.
2 strings =1 dc isolator they are 4pole derr and the clips man overdone it tried to do it neat but looks a mess
We tend to use one DC isolator per string. Don't like penny-pinching. Glad others agree. This type of wall is soft and crumbly which the clips wouldn't easily grip into so that's why there's loads of them. Anyway, it's in a loft where the homeowners rarely go so the appearance isn't a huge issue.
Reply to TL4000 high pitched whining in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
