TN-C-S / Pyro / Outbuilding Upgrade | Page 2 | on ElectriciansForums
Discuss TN-C-S / Pyro / Outbuilding Upgrade in the Australia area at ElectriciansForums.net
SW1970
Hi, bit of a job with scope creep going on. "Oooo it's so good we've found a nice electrician we can get all these things done that we've wanted for years". Client wants new outside lights on garage but existing isolation and circuit protection supplying garage is falling apart so that needs sorting too. Circuit to garage is on buried 2 core pyro of unknown depth and routing. Existing old Wylex isolator and fuse in meter cupboard is rusting and existing old Wylex isolator and fuses for lights and sockets has no RCD (sockets are used for outdoor equip). So these items need replacing and upgrading. Primary concern is earthing, installation is TN-C-S. Earthing to MET is ok. Have a look at this sketch (red is new equipment replacing old, blue is existing and propose to retain):
First time I've worked with pyro. Not sure which rating as existing terminations aren't marked so assuming worst case from Lenny's sticky it's 8.2mm2 equivalent. Any thoughts or guidance on this one? Many thanks as usual!
bet noone knows what heatshrink was---it came out about 25 years back but was discontinued it replaced the micc pots , had to use a special attachment on a blowlamp to terminate it
also there were pots that didnt screw on, they had a separate brass wedge instead-- and you had to use a converted set of molegrips to crimp the wedge into the pot
micc is very underrated imo this new stuff is impregnated with silicone so it doesn,t get moisture in the insu, not like the old days, no silicone then-- u had to work fast or the meggar reading would be low
if an old mineral had damp in it you used a blowlamp to drive it out after removing the pot
bloody sparks these days wouldn,t know **** from clay, if they were presented with an micc job
Thanks for all the comments. In this case the pyro is plastic sheathed.
Pyro can be buried direct: FAQs - Fire and Performance Wiring - Tyco Thermal Controls
So, it looks like it's all down to the earthing arrangements of outbuildings in TN-C-S installations (a well covered topic!), and depth/mechanical protection of the existing buried cable.
Wirepuller - I like your idea "As long as there were no obvious issues...no I wouldnt. I would just do a cert to cover work within the garage, as the refurb of the garage install and a few additional points is the object of the exercise."
But if the job includes the garage installation refurb and new RCD protection at the other end of this distribution circuit in the meter cupboard (per my original pic), are we comfortable with constraining the EIC in this way because this pyro cable is a fundamental part of the circuit.
This is a broader point than just this case. I guess the point goes: is it ok to certify an installation that we have added to or altered, if parts (that we haven't installed) don't wholly meet the regs, even though our works have improved overall safety of the installation? I was taught the answer was no, but that was in a different environment where there was usually budget to sort out any issues.
Are you worried about this MICC. If you have tested it, especially the IR and it is in good condition then utilise and certificate it. By testing the circuit you are confirming all the details on your SoTR such as the IR, Zs etc so that is ok.
As for you SoI there is nothing on the form that asks for a depth of a cable in the ground, so what will stop you filling out one for an already existing cable.
Hi glasgowbiker, this is from the tyco website. You're probably right, but this is an attempt to save a larger job worth about ÂŁ1,000 that is not going to happen if I can't re-use this pyro. These are lovely clients with a lawn that looks like it's manicured with a pair of scissors on a daily basis. Malcolm's comment is good; I shall declare the pyro situation in comments on existing installation.
Q. Can Pyrotenax cable be buried directly in the ground?
A. Pyrotenax cables are suitable for burying in the ground and are subject to the same procedures as other cables regarding the depth of trench, mechanical protection and identification of routes. We would always recommend plastic covered cable as some soils can contain elements corrosive to copper.
Here endeth the lesson :chillpill:
Reply to TN-C-S / Pyro / Outbuilding Upgrade in the Australia area at ElectriciansForums.net
Why go to the trouble of adding another cable, which I assume would follow the same route as the other ?. Why not upgrade it. It was to try to...
