SW1970
Hi, bit of a job with scope creep going on. "Oooo it's so good we've found a nice electrician we can get all these things done that we've wanted for years". Client wants new outside lights on garage but existing isolation and circuit protection supplying garage is falling apart so that needs sorting too. Circuit to garage is on buried 2 core pyro of unknown depth and routing. Existing old Wylex isolator and fuse in meter cupboard is rusting and existing old Wylex isolator and fuses for lights and sockets has no RCD (sockets are used for outdoor equip). So these items need replacing and upgrading. Primary concern is earthing, installation is TN-C-S. Earthing to MET is ok. Have a look at this sketch (red is new equipment replacing old, blue is existing and propose to retain):
First time I've worked with pyro. Not sure which rating as existing terminations aren't marked so assuming worst case from Lenny's sticky it's 8.2mm2 equivalent. Any thoughts or guidance on this one? Many thanks as usual!
