This is the current set-up.
There's a TNS incoming to a detached garage, this is split from an old MEM fused isolator (the tails go straight in) and has a send to the CU via some 10mm T&E going under ground and up into the house. There's another feed from the fused isolator to another, smaller, fused MEM box for the garage supply.
The service head's in a right state, there was a bit of red tape round one of the fuses holding most of the plastic together. The DNO are sorting this today and putting a new bond on to their armour so I can improve the earth, but this is a right headache to get up to 17th.
So far as I can make out, I'm going to need to create a MET in the garage, put a distribution board in the garage, and have a SWA (with the armour bonded to the MET) distribution circuit put under the ground to the house, and then a new CU with the armour from the SWA as the main earth in to the house and create another MET for the gas and water bonding.
I'm not looking to get into the CSA's here, that's just maths, but does the principle meet 7671?
Anybody see any problems with this?
