tns /tnc | Page 2 | on ElectriciansForums
Discuss tns /tnc in the Australia area at ElectriciansForums.net
T
trickyb
Hi i know most domestic installations are TNC but how do you tell? if theres an earth terminal on the side of the cutout does this automaticaly mean its TNC ? How do you test for this ?:confused5: thanks ian
Reply to tns /tnc in the Australia area at ElectriciansForums.net
Generally speaking local earthing will rarely be below a couple of ohms, so in parallel with a TN-S sub-ohm value will make little difference...
There is a section on the mains supply which will give the type of supply as TNS, TNCS, TT etc this indicates the method of earthing
