To crimp or not to crimp...... | Page 2 | on ElectriciansForums
Discuss To crimp or not to crimp...... in the UK Electrical Forum area at ElectriciansForums.net
Rob99
Sussex
I'm going to be wiring up a smart home panel in a couple of weeks using mainly 0.5mm tri-rated cable and wondered what the view is on using crimped ferrules on the ends of the cables to fit into the screw terminals of the various components.
Seems like a good way to avoid poor connections with stranded cable and the neatness appeals to my OCD side!
Cheers
Rob
I bet you love love Loving Spoonful as well.........
That one has flown right over my head mate.. :tearsofjoy:
I think ‘don’t quote me’ BS EN 60204 prohibits solder.
Or that could be just soldered joints.....hmmmm
Either way it would be a bit boring.
I did it at my last works. Used a solder tub thingiambob... What you call it...? a heater that melts solder in a pot and you just dip the wires in..?
Cars don't fall under BS7671.
An it's probably referring more to motor connections etc...
That is why the older electricians will die out, the 27th Edition of the regs will cover electric cars as you will be replacing fuse boxes and earthing straps in them in 2037. So many members on here so short sited.........
Reply to To crimp or not to crimp...... in the UK Electrical Forum area at ElectriciansForums.net
