To spur or not to spur?..... | on ElectriciansForums
Discuss To spur or not to spur?..... in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
littlespark
Staff member
Supporter
Patron
Solutions
Scottish Borders
Quick description. I've got a socket on the RFC with a double socket already spurred off it. This socket has been replaced with a blank plate with the joint in the box. Customer would like another socket installed nearby but in opposite direction. Brick wall
Solution 1. Change blank plate to SFU. Have both sockets off the fused outlet. (not a radial circuit, but 2 radials. with one point on each.)
Solution 2. Change blank plate to SFU. Have original spur on supply side, new spur off fused outlet. (Not altering what was existing)
Solution 3. Spend a little time chasing out the brickwork and have both spurs on the RFC. Replace the blank plate.
Im a little confused with option 2 also.
Are you saying the blank plate ( which is currently a spur off the ring) will be changed to a FCU then you will take the new socket off of the fused side.
So your end up with a FCU (that will be your 1Ă— spur point from the ring) then your new socket(s) will be spured from the 13amp output side of that ?
The way I read it is: the original spur will be fed from incoming side of the FSU and the new spur will be fed from the load side, I think.
I get you, so a spur off of a spur like you mentioned in post 3
No I see it as he will have 4 wires in the input terminals ring and 2 Spurs,the original spur and the new spur ergo 2 Spurs off of the same point on thRfc
Not strange. Its a realistic scenario I'm faced with.
No2 is as explained. 1 spur from supply side, 1 spur from load side. Is that classed as 2 spurs from the same point?
No1 is 2 spurs from same point, but that's fused down, so is it acceptable?
I wouldn't put 4 cables into one connection.
The blank plate used to be a single socket on the ring. There is no socket now, just a joint in the box.
Reply to To spur or not to spur?..... in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Luckily when I rejigged the socket to fit the fcu next to it, it meant the original ring wiring reached, i put the socket on the ring and took a...
I am a landlord/owner of a flat. I am just about to spur off nearby sockets to provide the additional 24hr supply to new Dimplex Quantum storage...
