To spur or not to spur?..... | Page 4 | on ElectriciansForums
Discuss To spur or not to spur?..... in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Not sure Pete. You could be right though.
It's borderline, I can see what guys are saying, still don't agree, but not going to continue the argument, solely because it is borderline to my way of thinking that's 2 spurs from 1 point, 1 unfused and 1 fused, not something I would have done.
But using that logic if you fitted a 13a FCU right next to a socket which was on the ring everything fed from the FCU would be a spur off a spur etc.?
Fused at the FCU via a 13 Amp fuse, perfectly acceptable
Thanks for that, Pete. Only 4 months late in replying:p:D
That's OK Mate time waits for no man as they say
Reply to To spur or not to spur?..... in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Generally it would depend on the circumstances whether the armour is earthed both ends or not, and not just dependent on whether it's 2 or 3 core...
Luckily when I rejigged the socket to fit the fcu next to it, it meant the original ring wiring reached, i put the socket on the ring and took a...
