To tie wrap or not to tie wrap. That is the question | on ElectriciansForums
Discuss To tie wrap or not to tie wrap. That is the question in the UK Electrical Forum area at ElectriciansForums.net
derby
I’m doing a 48way three phase board at work with 34 circuits. How to keep it tidy without tie wraps? Or is tie wraps the way to go
big boards like that, the only choices you have for a really neat job without spending days on it, tie wraps or if its big enough you can screw some slotted trunking down each side.
Use tie wraps to form the wiring into place.
Remove when all testing is done, as long as you ran them in neat, they shouldn't move too much.
Pet peeve of mine is cable ties where they aren't needed. An if I find people tying cables together in trunking. Heads will role. Nothing worst than having to pull out a cable in trunking an finding its tied to all the others.
The old school sparks I have worked with would have lobbed their hammer at you if they saw you putting ties around cables in trunking
I have a similar amount of anger directed at whoever tapes up bunches of cables before pulling them down conduit.
makes it almost impossible to pull an extra one down after
Reply to To tie wrap or not to tie wrap. That is the question in the UK Electrical Forum area at ElectriciansForums.net
Met landlord on site as he lives not far away and showed him which filters he needed so he could see for himself. Cooker is on inside wall of a...
Has the cover been removed, is it TP bussbar? I fitted one as @oscar21 linked to a few months ago, it was actually a nice board and with the TP...
