To trim or not to trim? | Page 2 | on ElectriciansForums
Discuss To trim or not to trim? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
As you say, you don't want to be cutting the wires back if the other fitting may need putting back at some point in the future.
A bit of sleeving over the wires where they go through the hole in the metal back plate would be worthwhile though as suggested above.
Reply to To trim or not to trim? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Thank you so much for your help with this light work perfect now thank you again much appreciated
Com is short for Common, sometime just C, or in the case of your old switch , L1 It is the side of the switch that is always connected… the link...
