Too large a ring main | Page 3 | on ElectriciansForums
Discuss Too large a ring main in the UK Electrical Forum area at ElectriciansForums.net
B
Boaky
I recently tested a new build (mostly new build) and found 45 sockets on a large ring main in an office environment.
My r1 was 1.6 ohms rn 1.6 ohms and r2 was 2.7 ohms which made my r1+r2 1 ohm roughly
my zs on the circuit was also 1 ohm although I didn't test all of them.
the protective device is a c32 MCB, common sense tells me this is wrong but can anyone tell me why and how to explain it to a spark who has done this twice aslong as me.
No Rcd needed as it's a managed building and all surface work although I would of used a RCBO
Also not getting why no rcd protection on this large skt circuit if installation is maintaind by skilled and instructed Person . Wot about all the office staff surely not all are skilled and or instructed ?? In my opinion all SO unless labelled as so for a specific purpose ie IT hub . Potentially in youse of normal folk need rcd/rcbo
im guessing you dont do much commercial design then ? :-/
Reply to Too large a ring main in the UK Electrical Forum area at ElectriciansForums.net
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
6K
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
