Probably been aired before, but how do the members rate the various Torque screwdrivers?, do they use them? and their opinion on the need to use them? if they have them what's the best set to get?
Discuss Torque Drivers in the Electrical Tools and Products area at ElectriciansForums.net
I use torque screwdriver with auger bits and I couldn't do without it on rewires. Can be used with spade bits but need good quality bits. I find not only easier to drill the hole with less pressure or room needed but extends the life of the drill bits.
it was clear mate, i think he is struggling with the english.Not sure what you mean mate, maybe my thread wasn't clear I'm on about the VDE insulated Torque screwdrivers we have all been advised to use when connecting up CUs
Wiha is very good, I use the torque set all the time, just change the heads instead of carrying different screwdrivers, couldn't be without it though.
One issue I have is knowing what torque to set it to on standard socket outlets and ceiling roses etc; we have the settings for pretty much all switchgear, but general accessories are a grey area, so I end up cranking it up to the highest torque when I do accessories etc, and do the good old tug test.
i quite like wiha myself, i find wera drivers too soft
Not sure about the rest of you but I am of the opinion that when the screw is as tight as my wrist can turn it without A) rounding or shearing the screw and B) it doest hurt then thats tight enough.
Granted everyone is of a different strength but I have today tightened up the terminals in at least 5 plug tops that I wouldn't even consider finger tight, on the flip side I remember trying to remove a earth from a DB years ago where I had my biggest driver, 2 hands and had to lean on it to loosen it!!
Reply to Torque Drivers in the Electrical Tools and Products area at ElectriciansForums.net
Thanks for visiting ElectriciansForums.net, we hope you find the Electricians Tools you're looking for. It's free to sign up to and post a question yourself to find a tool or tool supplier either local to you, or online. Our community of electricians and electrical engineers will do their best to find the best tool supplier for you.
We also have a Tiling Tools advice from the worlds largest Tiling community. And then the Plumbers Forums with Plumbers Tools Advice.
