Torque screw driver anyone bother ? | Page 3 | on ElectriciansForums
Discuss Torque screw driver anyone bother ? in the UK Electrical Forum area at ElectriciansForums.net
Dustydazzler
Supporter
V.Nearly Esteemed
Surrey
Ok tin hat on for a minute...
I have never ever bothered to acquire or use a torque rated screw driver
I have been offered a second hand wiha one by a mate for ÂŁ20 as he is buggering off to Spain to work
Are they worth using ?
Might be good if you know what the right torque setting is for fixing bake light surface back boxes and junction boxes to a wall/joist.
As the amount of times I've just thought to myself just another quarter turn will do.....then crack!! Fcuk!!
bakelite - Bing - https://www.bing.com/search?q=bakelite&form=EDNTHT&mkt=en-gb&httpsmsn=1&plvar=0&refig=f69a7ff551ac49afb6209ba61f1945a7&PC=HCTS&sp=1&qs=LS&pq=bakelite&sc=8-8&cvid=f69a7ff551ac49afb6209ba61f1945a7&cc=GB&setlang=en-GB
Edit Deleted and it's Bakelite all one word.
Surely it's urea-formaldehyde. :D
I checked the tightness of all the other terminations in DB not expecting much.........
Had to alter some wiring for differently abled use in a brand new house, first owner not yet moved in. Got 5 turns on one of the incoming terminals of the main switch. o_O
May be but it certainly aint Bake Light
A torque screwdriver is a pretty useless piece of kit unless it is very regularly calibrated, just a small drop or knock could affect it's calibration . If you get it calibrated every 12 months and it is found to be working lower than it's set value do you then go back to all your customers of the last 3 or 6 or 9 months to recheck your work
In reality the only reliable way of using one is to have a calibration unit and check the driver before every job but that is an expensive option that no one will pay for. Therefore the age old talk method of "yes that's tight" works for me
Reply to Torque screw driver anyone bother ? in the UK Electrical Forum area at ElectriciansForums.net
