Torque settings - hmm | Page 2 | on ElectriciansForums
Discuss Torque settings - hmm in the UK Electrical Forum area at ElectriciansForums.net
Pontypridd
Bought a torque driver today, any clue on recomended values for connector blocks, henleys, MCB ?
I imagine its cable size dependant? Anyone have a quick table i can print and laminate?
Please dont say manufacturer instructions! would be poop!
[QUOTE="
[/QUOTE]
It's very cable size depentent. CU manufacturers are (IMO) remiss not to always point that out clearly (some do). OK for bus bars and fat cables, but applying the "recommended" torque into a screw-down N or E terminal on domestic lighting can easily do this (pic). I've been called out and have come across CU with cables snapped right off. I often take the time to trim and re-dress the ends where I see this (which is quite often nowadays with the promotion of torque drivers).
[ElectriciansForums.net] Torque settings - hmm
Couldn't agree more Andy78! Many on here talk about "knowing the torque" and I truly believe they do, from years of experience. I fondly believe one instinctively knows when something is right...
We know some cables "creep", some soldered connections do particularly, some fine-stranded are susceptible to being over-tightened etc etc...
I am no expert, I just do 'em up...pause a while, then just check 'em again...that's what my dad taught me 50 years ago, and it has been good advice, from home, to caravan, to extreme marine use on 12v DC...
Amateur, maybe...never known a failure yet, but seen loads...
usually on 2.5 rings where the sockets are not tightened properly. Frankly, they need to design those terminals better, but that's another story.
Get a torque driver, keep it in your toolbag and produce it if asked...but I believe you should trust your hand and wrist first of all.
Its like being in the North again on a night out with the Northerners, all torque and no action and us smooooooth Southerners move in and cop of with the Northern lasses..........
Hey......not as easy as us up here copping OFF wiv an Essix biooty.;)
problem there is scraping off the make-up to see what you've got. like lancashire hotpot. you need to scrape off the grease to see what the meat's like.
Reply to Torque settings - hmm in the UK Electrical Forum area at ElectriciansForums.net
