Totally stumped. Night Storage Heater tripping out MCB, but ok on daytime circuit. | Page 5 | on ElectriciansForums
Discuss Totally stumped. Night Storage Heater tripping out MCB, but ok on daytime circuit. in the UK Electrical Forum area at ElectriciansForums.net
Swansea
Please help. I have a basic understanding of electirics, but 5 Electricians are stumped and I don't know where to go next. My mother in law heats her house by 4 Night Storage Heaters, all of which are wired to a Economy 7 supply/fuse board, with no RCD just MCB. The largest of the Night Storage Heaters began to fail and trip the MCD. To cut a long story short, she ended up having a new one fitted. Unfortunately this new one also now trips the MCB. The electricians have tried swapping the various supplies to the various heaters around in the E7 fuse board and the same heater is tripping the different MCB. It would be an obvious thing to consider that there is a fault on the circuit between the board and the night storage heater. However, they have now wired it into the day time board and it is not tripping. Has anyone got any ideas as we need to get it wired back into the E7 circuit??
im thinking the way they have connected the booster+storage heaters into the 24hour supply and it now works
i dont think they have taken the circuit from the e7 board and tried it on the 24h supply
rather they have taken the 24hour supply and put the storage heaters on that circuit outlet
thats all that i can gather/make sense of
The impression I got was that they swapped things at the DBs. The OP doesn’t mention anything about boosters, not all E7 installations have that feature.
What is the modal number and KW rating of this storage heater and how is the circuit connected to the 24Hr consumer unit?You state that the E7 consumer unit has 15A MCB's what is the rating of the 24Hr MCB it was put on?
either way, something is wrong and should have been figured out on the first visit before changing the heater then backtracing from there
im betting your old storage heater has made its way to the skip, or been crushed beyond repair in the back of a van
the OP is too unclear to make sense of, you need a site visit by a competent sparky
Assuming all testing has been carried out effectively and shows no issues. Based on the info the OP has given I would suggest running a temporary new supply cable from the off peak board mcb to the new storage heater and see if it still trips. If it does it must be the heater, if it doesn't it must be the circuit cable.
a permanent temporary?
We all know that the fault is probably quite simple, when found, at least. Until visiting site and having personal experience of the situation, I find some of the confident posts a little presumptuous. I don't tend to criticize other tradesmen without that personal involvement. Sorry if it upsets anyone but let's not presume we're talking about simple cockups (even if we are).
the replacing of the heater was a bit cart before the horse
it should not take 5 visits to be in the same/worse situation than you started with
Indeed....I spent 8 hours over 3 visits last week to trace what turned out to be an intermittent lighting fault.
Reply to Totally stumped. Night Storage Heater tripping out MCB, but ok on daytime circuit. in the UK Electrical Forum area at ElectriciansForums.net
Yet another update: I believe what EDF have done is moved me from an Economy 9 to an Economy 7. I've just emailed them to ask if they can switch...
