touch voltage help | Page 2 | on ElectriciansForums
Discuss touch voltage help in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hmmmm I don't think so...
Stick with the dedicated SY glands...
Sent from my Xperia S using next doors WIFI
i know you should use the correct part designed for the job but always thought the ring in the external swa gland would tighten up on the taper enough to hold the braiding in the swa cable, therefore the braid would be held on earthed.
I maybe and probably wrong but was always under the impression that the correct sy glands are expensive?
opening my self up for abuse now, I've never had to use sy cable so ill stand corrected
The sy glands actually clamp the braid the same as a swa gland. It's just that it uses a rubber grommet to clamp the braid to the steal cone. But there are some that just work like a brass to rubber, in which case you would put a lug on it and earth it. That's probably the best way as unless they clean up the area of paint it might not earth proper anyway.in either case it should be earthed which would eliminate the voltage or show a fault in the cable which you could pick up with a insulation tester between e cores and the earth.
It is possible to use a CW or E1W gland on SY. If you double the braid over at the end where the olive sits, it clamps the braid to the body of the gland. I've used it before and wouldn't hesitate to use it again. A tug test is a good idea, before the back compression seal is tightened.
Reply to touch voltage help in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
That's brilliant Dave, thanks again. I had to raid my sons felt tips and pencils for any colours available! Apologies for the strange and...
4K
In the 80's I was taught that with PME earthing arrangements we used 16mm for the main earthing conductor, some went a bit crazy and were bonding...
