Transformer rewind wire query | Page 3 | on ElectriciansForums
Guest viewing is limited
Discuss Transformer rewind wire query in the UK Electrical Forum area at ElectriciansForums.net
North yorkshire
Hi
I have a Transformer, that needs a rewire on a Secondary windings, the wire that was on it, was a muti-core wire 9 strands, (0.06mm x 9) ( each strand enameled ), soldered together at each end, and laid on top of the primary winding with 175 turns, with a copper tape between the primary and this secondary .
Question: This multi core (Litz) secondary winding is supposed to have a output of 420v, but with only175 turns it will not equate to 420v, but if all the strands of the Litz was classed has a single turn then that will equate to 420v !.
I just don't get it .
Transformer outputs are:
Primary: 0: 0 – 240. V, P1,P2,P3
Secondary 1: 0 – 420. V @ 3 mA , S3
Secondary 2: 0 – 6. V @ 32 A , S1
Secondary 3: 0 – 12. V @ 400 mA, S2
Cheers
Spike
ps: think this might have been posted twice !
  • [ElectriciansForums.net] Transformer rewind wire query
I wondered if the two electrolytics were in series (with resistors across) to get the voltage rating, as they look quite small!
I'm concerned at the idea of moving/re-soldering the resistors. If they've got really hot, the growth of intermetallic compounds in the solder has made the joints brittle and they will be difficult to work on, and the reliability will just get worse and worse with tinkering!
Am I worrying unnecessarily?
If it's arc splash rather than heat then maybe.
Hi
I don't see a problem in raising the ceramic resistors away from the board and the relay, the new solder will replace what is there !.
I am wondering if, with the secondary winding that is laid on top of the primary , could it pick up any voltage from the primary !.
Spike
Hi
Yes you are correct, is that condoned ?, I do keep looking on ebay, but would rather see if I can sort it myself though, bit of a challenge tbh.
Spike
You obviously enjoy a challenge - but I was thinking another one for parts might be an overall cheaper and more reliable way of obtaining spares (eg a transformer!).
Do you know if the electronics still works?
If not, have you considered re-instating the transformer without the 425V winding, and seeing if the thing has survived? Or using a bench psu to run it? It would surely be frustrating to rewind the transformer only to find a trail of further issues?
Hi
You may find the solderability has become very poor, and difficult to get solder to flow to make a proper joint. It may not matter to you, but in the commercial world it's a concern, as the joints become unreliable.
'pick up' only in the sense that insulation between the primary and secondary could break down. Thats why you need the layers of yellow polyester tape insulation between the two - as per your pics?
No I don't, but that is exactly what I am going to do see post #18., then connect it up if I am getting a reading on the secondarys
Spike
If I employed someone to do some statutory periodic PAT testing for a fee and he/she turned up and used a PAT tester which they had repaired themselves after clear and major damage - I would refuse to pay them. And consider what else to do.......
But you may be doing this 'for fun' to see if you can get it working again and then you intend to bin it because the integrity of this test equipment is shot.
No I don't, but that is exactly what I am going to do, see post #18, then connect it up if I am getting a reading on the secondarys
Hi
Thanks for your reply, yes it is purely a challenge for me, and believe me I like a challenge , it also won't get into anyone elses hand, so def you won't be paying me to do any PAT Testing for you, actualy they don't use that term now, in the 18th edition it is called "Appliance Testing" , didn't include static Appliances but now does, so don't lose any sleep over it .
Spike
No, I meant any magnetic flux etc !.
In an ideal transformer all the flux links all the windings. In practice the coupling is not perfect, hence leakage reactance. The physical arrangement thus affects the regulation and efficiency slightly, but not the the transformation ratio.
Reply to Transformer rewind wire query in the UK Electrical Forum area at ElectriciansForums.net
Recommended Sponsor News
Hi everyone,
