transformer | on ElectriciansForums
Discuss transformer in the Australia area at ElectriciansForums.net
WA
hi
i have a battery charger which has stopped working
after checking the transformer, it seems like its us
what size transformer do i need
12v battery 3.5amp charger
i think i need a 14v out put
power supply is 240v
the ones i have seen on ebay, all seem to be 220v 40w
thanks
hi
thanks
there is no output, its dead
i havent been able to find a transformer that gives out more than 12v, it jumps to 24v
if you get a 240/12V tranny, you will find the output is >12V on no load. it's the D.C. output after rectification that matters. I have a spare one in stores, came out of an alarm panel. yours for postage cost if you want.
Reply to transformer in the Australia area at ElectriciansForums.net
If you are not bothered about the type of connector on the adapter, and you are happy to splice the output of the adapter directly to your...
It should give fairly accurate results. Bear in mind your car will probably have a smart charging system, so worth having a read up on those.
