Hey, I've been asked a question 'what are operational systems on Transistor H-bridge system for a conveyor motor with speed control property's'. I know that system I've put below would work for a lower voltage application, I just cant seem to find any information on high voltage applications. I know how the H-bridge system works but I just don't know what would be used for the speed control. I'm assuming a 555 chip wouldn't be powerful enough to operate a conveyor system? I'm just wondering what another option would be for this application if a 555 chip wouldn't cut it?
I'm also basing this on it being a 1-phase system. I'm hoping that I can get away with a 1 phase system because I don't know how I would draw a 3-phase H-bridge system. Could this application get away with being 1-phase or would i need to look in to 3- phase.
So far this is my answer:
On a 12 volt system when the voltage is supplied to T3 and T2’s side this will open T2. This is because the voltage on T2 between the gate and source will be 11.45 volts, where as the voltage to between the gate and source on T3 will be -0.55v closing the gate. Whilst this is happening on T3 and T2 side the opposite will be happening on T1 and T4’s side, T1 will have -12 volts opening the transistor; letting the power travel from T3 to T4. When power to T1 and T4’s side is present this will do the same in reverse opening T1 and T2. Having T1 and T2 open will make the motor spin one way and when T3 and T4 are open this will spin the motor the other way. The Voltage for a conveyor system will be a lot higher, therefore the components used will have a higher voltage but the same principle will apply
Any help would be much appreciated, as the questions I get are based around things that I haven't been taught about in the slightest.
