trying to find an S14s light fitting | on ElectriciansForums
Discuss trying to find an S14s light fitting in the Lighting Forum area at ElectriciansForums.net
Towcester
Hello,
I have an S14s light fitting in a large cupboard with a pull cord attached to the fitting. It wasn't working so I got a new bulb (Architectural LED Strip Light 6W Opal 500mm S14s Bell) , but it now looks like its the actual fitting that is defective as the new bulb works fine in the same fitting in another cupboard, but not in this one. I can't find anywhere that sells new fittings of this type. Anyone know a possible supplier ? Thanks.
Have you checked you are getting power to the light fitting, and a fuse has not blown?
Only mess about with the power on if you are competent to do so.
Reply to trying to find an S14s light fitting in the Lighting Forum area at ElectriciansForums.net
Thanks for you response, that makes more sense LEDs do produce less heat. I think i read somewhere that LEDs are more sensitive to heat, as in...
Hi Avo Mk8 Thank you so much! Yes the bulbs fit perfectly I don't think they are much bigger. I could have bought a bigger rated LED driver but...
