F
frisbee
I have a 1920s house with what i think should be a TT earth system. Basically, there are two cables from the overhead line (live / neutral) and there is no earth connection to the meter head which you would expect from a TNCS system. There is a 4mm earth cable that goes outside but not connected to anything - i think this was once connected to a earth rod and i will get this sorted.
I have a MEM metalclad consumer unit, it has a 100A DP isolator and some RCBO's (30ma) for sockets etc and some MCB for other circuits such as lighting. I intend to keep some of the MCB's so will sort out the wiring on these circuits to make it comply.
1. As its a TT system do i need to swap the 100a isolator for a RCD. With the new regs it mentions about not having a common RCD so not sure how i get around this. Can the RCD be installed after the meter but before the consumer unit (so outside the CU and separate from this)
2. What sort of RCD is needed (what rating and time delay)
3. What size earth cable is needed to connect to the earth rod
I was a electrician 15yrs ago so i have a basic knowledge just need to get back into the swing of it
thanks
thanks
