TT earthing and supply | Page 2 | on ElectriciansForums
Discuss TT earthing and supply in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
January's professional electrician
Thanks for taking the time to post the images jamie
Have to go,I'm just nipping to the surgery to get one of those neck braces lol
It is interesting that the non discrimination is shown as a type S 100mA RCD tripping in 100ms at 60mA, which does seem a very poorly designed RCD since the minimum time delay should be 150ms and the RCD should not trip until 100mA (though it is likely to trip earlier, 60mA seems a bit low)
60ma does seem low. But when ramp feasting 30ma RCDs I find it can range between 17ma-25ma with out going load disconnected.
I have fitted a few of these 100 ma s type RCDs recently with 30 ma further down stream on a farm. I may be going back, pretty soon so I could ramp test it and check tripping time and post the results
Doesn't really matter whether you fit a 100mA or 300mA S type to be honest on a TT system, as additional back-up for 30mA RCDs downstream. What i will say, is of what must be by now, the many hundreds (if not more) of times we have used 100mA S type RCDs for discrimination purposes for downstream 30mA units, i can't remember ever having problems such as been described in this article!!
I must have a more in-depth read, as i haven't had that must time these past couple of days, and have only had a quick over-view....
Reply to TT earthing and supply in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
It's not the same scenario, though. Tails more than 3mtrs can be overcome by using a fused switch and rcd board, whether the earthing system is...
Indeed it would be. But that would mean having 2 things to disconnect instead of one. More margin for error. Of course, any diligent spark would...
loz2754
L
