La Poste
Greetings.
I am working at a friend of the families house helping to make the place safe and will be shortly arriving at the decision of what earthing system to use.
The house allready has an earth rod although the readings on it are rubbish.
The main bonding is giving an earth fault loop impedance of 18 ohms, much better than the rod I might add.
The suppliers have said TNCS is available but after reading much on the subject of earthing I'm a little undecided.
I have read about losing a neutral on the siupply side that is pretty much catastrophic if you have TNCS.
Also the neightbours electrical standards are pretty low from what I have heard and with TNCS I might be importing a whole lot of aggro from next door.
The thing that puts me off the earth rod is the high earth fault loop impedance. If the gentleman in question had a faulty RCD then if he had an earth fault no MCB's would trip, the earth fault current wouldn't be high enough with an earth fault loop resistance of 18 Ohms.
In doing my research I have realised some people have very strong views on this subject so I am asking which earth method would you prefer?
Thanks.
Thanks.
