B
bigd
Dear All,
Had a heated discussion with another electrician today regarding TT installation. So your advice would be greatly appreciated.
Does a consumer unit (installed as part of a TT systems) with ALL circuits protected by 30mA RCD's require an additional 100mA RCD on the incoming tails? The consumer unit has a main switch and 2 30mA RCD's.
I know its normal practice to replace the main switch, in the consumer unit, with a 100-500mA RCD (Usually s-type time delayed), but this wasn't possible due to the design of the consumer unit (the manufacturer didn't have this option - a lesson learnt here stick with well known makes wylex, MK etc)
I also realise that any dedicated circuits for smoke alarms, medical equipment etc would require me to fit a 100mA RCD in the incomer, but there were no dedicated circuits just those protected by RCDs
The other electrician disputes this, saying all TT installations need a 100mA RCD.
Your thoughts?
One thing I did think is that where the consumer unit main switch feeds the 2 x RCDs the cables are considerably smaller than the incoming tails so the RCD feed cable could fail before the 60A DNO fuse. But then again the consumer unit is rated at 100A and the RCD's at least 63A, so I would expect the cable to survive. Am I thinking on the wrong lines here?
Dave
Your thoughts?
Dave
