- Joined
- Jan 24, 2010
- Messages
- 33
- Reaction score
- 2
hi,
need some help with this one;
I'm testing a board that is TT but doesn't have an RCD as main switch, it has a standard 100A switch disconnector (60947-3). However, every circuit in the installation is RCBO protected. Is this ok?
Just to make matters a little more awkward the supply cable is a 25mm single core PEN conductor with the outer sheath used as the neutral. The regs seem to be saying that RCD's shouldn't be used as there is no seperate path for earth currents, there is however a 16mm earth conductor which has been taken out to the earth electrode.
any help with this is much appreciated
thanks in advance
thanks in advance
