TT System questions | Page 2 | on ElectriciansForums
Discuss TT System questions in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
i got the local electric compant to convert it to pme for nothing that must be better !!!!!!!!!!!!!!!!!!!!!
Please explain how a PME supply would be better for this industrial site?? You have a ''True Earth'' with a Ra value of .03 ohms. You can throw out all special tripping times imposed on a typical UK TT system!!!
Mind, i would be a little doubtful myself at that .03 ohm reading, but i could well believe a .30 ohm value, that is very much achievable in a good resistivity soil area...
Yeah there is a lot of planning gone into the setup of the site, there is tape, mats and rods with some interconnected via each other.
My question remains though does it still require a time delayed main switch back at the point of origin? even though values are met?
I personally think that yes the requirement is still needed, but would it be beneficial to start fitting RCBO to every final circuit?an industrial special location it is something i have never seen before.
In a domestic scenario not a problem, or in an agricultural scenario too. But the fact that this is an industrial site i am not 100% sure
the joys of TT
ha ha
With Ra levels that low (and i do still doubt .03 ohms) that is proven stable, why would you be making special considerations that are based on Ra's of around 200 ohms??
I hope when you tested this extensive TT system you used a dedicated earth tester, and not relied on your MFT. and that your test spikes were placed outside any Zone of influence?? Otherwise your test results would be considered to be unreliable and be probably incorrect....
Do remember that they are documents from the US DoD and so are for information only, if BS7671 or other documents differ then the UK standards must be followed.
Reply to TT System questions in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I think there is a little truth in what the guy in the video says, but he makes more out of it than he should. A N-E fault on a circuit protected...
Yes Table 3A that was in Appendix 3 of the 17th edition of BS7671 and in BS 7671:2018 (Blue Book) up to the release of BS7671:2018 +A2:2022 (Brown...
