2tag
Hi minds my first statement is that I am not a electrician my back ground
is very much in coms, the reason for this post is I recently visited a friend,
who lives in a remote part of Southern Ireland not far from knock, on the west coast.
The cottage itself was supplied by a TT system hence the large earth rod stuck
in the ground outside the cottage and the board RCD protected. From what I
have heard that in the event of an electrical fault, that the earth fault loop path
travels down the earth rod back to the supply transformer hence tripping
Main RCD on board, I know that RCD are extremely sensitive piece of equipment
and it won’t take much to trip. My question is the earth fault loop path taken into consideration the cross sectional area of earth itself the terrain around the cottage is for the best part very boggy and heavily burden with clay surely under
fault conditions the fault is just dissipated within the earth itself and not via
the supply transformer after all what consuetude’s for earth. So I find it hard to believe that this fault path actually occurs. On my return to my job I asked the in house electrician the very same question, which for some reason he offered me no viable explanations, and in fact got pretty peed off with me asking. Please can any one explain this dilemma that I have? Thank you for taking time and reading this post.
