I've just changed a surface double socket to a flush one and tested it the reading I got was 2.5k ohms!!!
I checked the earth wire to the electrode and it was a 6mm ,the electrode itself needed cleaning which I did with a file and replaced the earth clamp this improved the reading to 26 ohms. The main switch is a 100ma RCD I assume that I need to incorporate either a 30ma rcbo on the sockets or change the board to a split load board with 2 x 30ma RCD's and a 100anp mains switch is thjis correct?
