tt system | on ElectriciansForums
Discuss tt system in the Talk Electrician area at ElectriciansForums.net
H
hughesy
hi guys, need some help im wiring a indoor arena on a farm never done this type of work before so not sure what is required am going through the regs but could do with a quick anser . firstly do i need to crossbond all the steel frame work and can i put an earth rod in for the earth of the building and will i need to install a lightining protection system ,i am new to this area of work as i am mainly domestic but like a challenge and dont want to turn the job down lots of help will be greatfully accepted.
I've never done any of this before either so best of luck!! Please don't just accept a quick answer but research it fully. As it's a farm all of your safety values are halved. Where is the feed coming from? is it an existing install that's being adapted? Don't be scared of anything it's just like a house but easier to install. All the steelwork should be bolted together otherwise it will fall down, I reckon thats the supp bonding but main bonding still needs to be done. The only problem you would get from too much "earth" is too high a PFC , your mcb is probably only rated to 6K. Please let us know how things go as this is an area I feel few of us know enough about.
There are a fair few things that need to be taken into consideration with this type of install.
Im not sure you could say its just like a house but easier.
If livestock are going to be part of this and its classed as a farm building there is a specific section in the regs that covers this. Its not as straight forward as you think!
jeremy you are right , im going to reference it all through the regs and get some more advice and learn how to put an earth rod in the job is not till jan/feb so pleantyof time to start planning will post a thread when ive made some proggress , i cant even remember even having to look at an earth rod in college whats all that about.
live stock wont be living there but people will be horse riding as its an arena also the only electrical supply is for the lights which is coming from a lighting circuit in the barn next door via sub main as long as i can do that got alot to learn on this but am looking forward to it.
Reply to tt system in the Talk Electrician area at ElectriciansForums.net
It's not the same scenario, though. Tails more than 3mtrs can be overcome by using a fused switch and rcd board, whether the earthing system is...
Also use a tails gland and clamp if available and make sure tails are secured to a wall. The danger here is a live to earth fault in the Consumer Unit
