Turn signal problem | on ElectriciansForums
Discuss Turn signal problem in the Auto Electrician Forum area at ElectriciansForums.net
Dallas, TX
My car a highly modified 1951 Studebaker, which was professionally wired (but with some issues I had to fix) now has a problem with the turn indicators. They had been working normally until recently. Now they work just fine as long as the head lights ae off. As soon as the headlights or parking lights are turned on the flashing stops. Also, the 4-way flashers also do not work when the headlights or parking lights are turned on. I have gone over the wiring as much as I can without tearing it all apart and have found no problems. The taillight bulbs are Leds, but the front turn indicator/parking lights are incandescent bulbs. I have Led compatible flashers for both the turn indicators as well as the 4-way flashers. Any ideas would be greatly appreciated. Larry
I would be looking for a bad earth connection somewhere.
maybe unbalanced... the flasher might be looking for all LED.
To a control unit thats designed for LED, something like a filiment bulb will appear as just a piece of resistive wire.
Thanks for the replies. I got tow led bulbs for the front parking lights and now it doesn't flash at all. I double checked the supposed led flashers I got, and they are not led compatible, my mistake. So, I will get led compatible flashers and see.
Ok, after trying two different flashers supposedly for Led bulbs, I got one that also has a ground wire, and it worked. I now have operating turn signals and 4-way flashers. Again, thanks for the help. Larry
Reply to Turn signal problem in the Auto Electrician Forum area at ElectriciansForums.net
Most likely a ground fault, check for corrosion of wires or terminals that connect to the chassis or body panels, particularly around the back of...
Thanks a lot FG; Thanks for that solution, I was looking along the same direction and yesterday ordered two 5 pin 12v 40A relays from Amazon and...
  • camperVanGuy101
  • Australia
  • 2
  • 649
Hi Did you fix your lights? Would love to see a photo of your bike!
Greetings. I'm having problems with the hazard lights in my 1999 chevy Blazer. It works as expected for some time with both sides blinking and...
