W
Welshsparky
Got a customer who is adamant he has 2 Tv coax's buried in the wall and he wants to find them. What would be the best method to do this?
Discuss Tv point help in the UK Electrical Forum area at ElectriciansForums.net
Cables come from the loft , He can see were they drop down but he wants to keep damage to the wall to a minumum, He's hoping to locate the exact position they were cut!
Are cables damaged? Cable tracer prob be your best option there thenCables come from the loft , He can see were they drop down but he wants to keep damage to the wall to a minumum, He's hoping to locate the exact position they were cut!
get him to rent a fluke cable finder for a day (the small one) it puts a tone down and uses non-contact finder unit to beep out the cable....
Remove all the aerial leads from all the TV's and at the wall outlets.
Remove the Aerial cable at the aerial, and isolate from elsewhere.
IR the core and the braid at 250v wrt earth.
If IR > 22K then connect the Braid to the mains, through a 22K 3W resistor, and trace using a cable finder.
Reply to Tv point help in the UK Electrical Forum area at ElectriciansForums.net
