Twin&earth and SWA installed loose on floor | Page 7 | on ElectriciansForums
Discuss Twin&earth and SWA installed loose on floor in the UK Electrical Forum area at ElectriciansForums.net
Warwickshire
Hi All,
The contractor working for Magnet Kitchens at my brother's house has run the sockets ring in 2.5 T&E, plus an SWA for the cooker supply, by laying these cables on the floor under the units.
I'm fairly sure this isn't acceptable - at least these cables should be clipped up against the wall (shouldn't they?).
We had actually expected the cables to be chased into the wall before the units were fitted, but they've done the electricals and plumbing after the fitout...
Any thoughts or comments? Many thanks.
The job hasn't been signed off or certified yet. Anyway, I'm advising that my brother shouldn't accept this work.
The contractor was going to do the external run in T&E until my brother (a civil engineer by profession) insisted that SWA be used.
Just been looking at this thread again, and have to ask why would your Brother stipulate SWA?
looks like SWA as Andy says, with the bedding exposed, going to the isolator,and some stripped out inner from isolator to CCU. whatever it is, it's a complete abortion and needs ripping out.
and i got a "bad spelling" for that by a member who's posted less than 30 times in 8 years. hmmm.
Cable Specification: NYY-J Mains and Control Cable Non Armoured manufactured to standard IEC60502-1 and VDE 0276-603 and available in sizes 5mm to 16mm and in 2, 3, 4, 5 and 7 cores. The cable features solid plain copper conductors, PVC insulated, PVC filler, PVC outer sheath. Black. 600/1000 volts grade to IEC60502-1 and VDE 0276-603. For installation indoors and outdoors as underground, or in cable ducts, installations with additional protection where mechanical damage is unexpected.
Am I reading this right?
Reply to Twin&earth and SWA installed loose on floor in the UK Electrical Forum area at ElectriciansForums.net
Although it might appear that I am being elusive with the facts, the point is, only you know what your worth is per hour and how long it will...
    • Optimistic
I assume said contractor is part of a Part P scheme (NICEIC, Napit, few others..) in which case complain to them. They'll investigate (in theory)...
