Two consumer units backfed | Page 2 | on ElectriciansForums
Discuss Two consumer units backfed in the UK Electrical Forum area at ElectriciansForums.net
mick b
bolton
I have just come across a domestic installation that has two consumer units I was asked to wire extra sockets and do a board change as well. I found that the sockets of one board circuit are interconnected to a circuit from the other board, thus back feeding each other. This means that unless you isolate both boards or pull both relevant fuses then the whole installation remains live. I have wired my additional sockets to my own board , and explained to the client what the problem is. There is no way to find where these two circuits are interconnected without ripping up boards or going in loft and emptying it. And it's a possibility that it's been done more than once. Apart fron putting a warning notice for two sources of supply what am I meant to do. Mention of tearing the house apart was not well accepted.
Just identify the two 'common' circuits and if it isn't a wrongly connected RFC get all cables together in one board and one MCB, obviously making sure the rating of the OCPD is correct for the circuit.
Exactly. But who is going to find a fault that until I arrived , no one knew existed , and will they let me turn off all the sockets in the house, or pay me to put right something that never existed until I turned up, on a never ending goose chase around the house
Why would you turn off all of the sockets in the house? Why would there be a never ending goose chase? Only incompetent idiots attempting to find faults will go on never ending goose chases.
If they are not happy to have the fault rectified the walk away and don't do any work. Carrying out alterations/extension/addition to the installation knowing that a very dangerous fault exists is negligence on your part.
Reply to Two consumer units backfed in the UK Electrical Forum area at ElectriciansForums.net
If two tariffs are sufficient, and you don't need too many ways, you can easily add an SPD kit to the Fusebox F2014DT dual tariff board. The only...
