two consumer units | on ElectriciansForums
Discuss two consumer units in the Australia area at ElectriciansForums.net
mcm
hi all
asked to change two boards the other day to new 17th boards. the two boards was running from the same supply i.e single phase with 100amp main fuse. has anyone else seen this before and is it acceptable.
Yes it's fine I have changed a few, one one set up I had to make a board and a half day rate and the other half off peak tarrif, just meant buggering about cutting busbars and fitting an extra main switch, but I used a couple of 15 usable ways Wylex's with flexi internal conductors so I could shove stuff around
Pict
Reply to two consumer units in the Australia area at ElectriciansForums.net
