Two rings in one room | Page 3 | on ElectriciansForums
Discuss Two rings in one room in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
We Still need to protect those who may switch off the breaker for one ring, test one socket in the room with a plug tester then treat all the sockets as dead. Remember you also might do a proper isolation on one board and not realise that some of the sockets are being fed by the installation next door. Nothing will show up on the board you have proven dead
Thats why you would prove dead at the point you are working at. Not just one socket, but every one you work at. Thats why locking of is a good idea too
Reply to Two rings in one room in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
As the cable itself has had the cpc cut off at both ends I would enter a C3 as it doesn't offer any protection within the cable if accidentally...
In addition, can you show the junction box with the cover off? Isolate the supply first, obviously. It sounds strange, what you’ve described at...
