Two way and intermediate switching | on ElectriciansForums
Discuss Two way and intermediate switching in the Australia area at ElectriciansForums.net
D Skelton
Mentor
Nearly Esteemed
Milton Keynes
How do you guys do it? Referring to the two pictres below, what are the pro's and cons to the two different methods? I'm trying to settle a minor dispute with a friend :)
[ElectriciansForums.net] Two way and intermediate switching
both ways are acceptable, i use the left one if only to do away with 1 choc connector. BTW, where the hell did you get the software to do such diagrams. i've been looking everywhere.
Well DS take no notice as it seems we are the only 2 so far that do it the right way, the others would rather stuff 2 cables into a small termination of a switch plate and leave the chance of having a poor termination that could be a point of an heat spot that could lead to a breakdown or in the worse case heat damage and fire .............:shades_smile:
That was my exact argument too :) at least with one termination in each you can bend the cable end providing a nice tight termination but with two cables, terminated into one termination, you can't do the same for both.
Edit: Just realised what a mouthful that sentence is haha. termination termination termination
but with 2 ends in the switch terminal, there's less chance of a single end missing the screw and falling out. all depends as well on the size of the hole.
:6:
Malc/Skel
you two must really struggle when doing a two way using a three core and earth. Getting the strappers, s/w, s/f in those pesky terminals. Or is done using connector and taking the s/w to other com term?
:6:
And when putting a single cable in a hole we double the end over, effectively making it two cables to fill the hole. So is there a problem in getting two cables in a hole?.............ER no.
What on earth are they on about Tel'?
I would have made that point too, although I would have been a bit less patronising in the way I made it :)
Malc/Skel
I'm not quite sure I understand your question. Am I being dumb?
Reply to Two way and intermediate switching in the Australia area at ElectriciansForums.net
Thanks again for your help, now solved đź‘Ť
brilliant thanks for your support. Lee
