D Skelton
Mentor
How do you guys do it? Referring to the two pictres below, what are the pro's and cons to the two different methods? I'm trying to settle a minor dispute with a friend :)
But you young,uns have been brought up on this single core conductor, where as with a good old bit of 3/029 you could always take a stand off to make it fit easier.
BnD lol I have to admit that I wire 2 way with the 2 conductors in the L1 L2 terminals, it was just for some reason I was taught intermediate with connectors, I blame my sparks who trained me he was a cantankerous old sod
so shall we now discuss the merits of choc block vs wago vs crimp . tin hat on.
Malc,
Cant beat a good ol' fashioned bodge:shocked3:.
As soon as the "one cable in the term" was posted it was only going one way.
Got to have a laff.
I sir take great offence at that I think it must be duel to the death with the weapon of your choice I choose a length of 20mm galv conduit with a strategically placed offest in it to inflict severe damage.
Okay, How do you do a two way circuit?
With the switch feed in the common and the switched live in a choc block as in the picture on the right. Personally, I find it a nicer layout within the confines of the pattress/KO box and also because I like to fit one doubled over cable end in each termination rather than two straight cable ends.
choc block all the way!
I use method 1 if I am awake and method 2 if not. Usually use method 2. Also as someone has suggested would not break all cores at intermediate and leave one core intact. Both are correct as far as I know.
They are both wrong.I suppose its a matter of who and how you served your time.
For me its feed to switch 1,switch wire from switch 2 and strappers between all switches.
I know a lot of you guys are fond of 3 plate system but I can't buy into having a permanent feed at a light.
Perhaps if the manufacturers considered providing another isolated terminal on the switch plate? Not just for 2 way & intermediate, but for loop in neutrals too. It would save the floating connector - which I suspect and hesitate to suggest, may technically not be permitted anyhow.
I'm with nolnoc, I was taught at college to wire looping at the switch. Supply >sw1 >however may switches you want > sw wire from last switch to light. saves time up a ladder which is apparently the cause of many an injury.....
there better be a very good reason for the resurection of a discussion that ended 2 years ago or theres gonna be a right trashing of some chumps post...........
D Skelton
Mentor
Milton Keynes
United Kingdom
Heavily Qualified Electrician / Teacher / Tutor - etc
Two way and intermediate switching
Australia
D Skelton,
oldtimer,
