Two way conversion - cable laying problems | Page 2 | on ElectriciansForums
Discuss Two way conversion - cable laying problems in the UK Electrical Forum area at ElectriciansForums.net
R
ricci07
Hi, this is my first post on this forum.
I am a traning electrician on my third year of college (level 3 2365), should have had an apprenticeship by now, but hey, I'll be the last it seems...
anyway....
i recently moved house to a place which has the worst switch/sockets locations.
i have done surface trunking socket Spurs for more sockets but have never chased a wall, lifted a floorboard etc...
i need to know how the best way to go about adding another switch into my lounge so I don't have to walk across a dark room when I go to bed.
I don't need to know about the wiring, just the cable laying.
i don't particularly want to use mini trunking from on switch down to the skirting board and around a door frame and to the new to switch location, so I would have to lift floorboards it seems.
we just had new carpet put down, how do I rip that up, and the floorboards and the right floorboard(s) and the correct amount of floorboards?
I asked at college and he said to use trunking,Mobutu I forgot to say there was a door frame I would have to vault over too.
any help would Be welcomed :)
Riccardo.
1st fix (chasing walls, lifting floorboards, running in cables) should be done first, then you plaster the walls, put in the skirting boards and do the painting, then the 2nd fix can be done over the top of that so you don't end up with all the sockets and switches stuck to the walls with paint.
Carpets, curtains and other soft furnishings go in last so they don't get spoiled by building work.
Have all the other lads on your college course got apprenticeships except you ? Why is that ?
You should not be doing any work without the councils permission and I'm pretty sure they will not give it for you doing electrical.
as already suggested get them in to do any work you want.
Reply to Two way conversion - cable laying problems in the UK Electrical Forum area at ElectriciansForums.net
This is an interesting issue. I agree with you however I took this to task with a scam inspector some years ago and we agreed to disagree that...
Often in old wiring, live to the downstairs switch, then in twin (or twin & earth) the two switched lives to the upstairs switch, and a single...
And if it's a garage then use metal clad accessories.
Thanks mate.. I've thought of another idea... can I not make a hole in side of the chimney and then stick an extention through by opening the...
