tyre pressures | on ElectriciansForums
Discuss tyre pressures in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
haj
East Yorkshire
Anyone have a manual foraVauxhall combo 1.3cdti ? Would like to know what the tyres should be at checked some sites and they say 35psi but that seems a bit low to me.
Regards
Haj
there should be a sticker as you open one of the doors to tell you that. failing that, stick 32 in the front, and 35 at the rear. it'll be fine. trust me :shades_smile:
Regards
Haj
if 35 psi seems a bit low to you, try 80 psi. I heard you get really good mpg with the only negatives being very little grip on corners (a small trade off). Let me know how you get on.
- - - Updated - - -
Regards
Haj
35 sounds about right for standard car tires.
My car a c1 is pumped to 34psi
Then again its only 800kg.
A transit has recomended psi of around 60
Don't go over the max embossed (raised) on the side wall of the tire
what's wrong with a swift kick? anyway, if you come over to scouseland, you won't worry about tyre pressures, you'll worry where the bloody wheels have gone.
Reply to tyre pressures in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
P
water pressure problem, unvented system I'm trying to sort out a problem with low water pressure at my elderly parent's house where they have an...
plomero
P
S
Low pressure mixer spray tap recommendations ? I'll be installing a new kitchen, DIY, and the Mrs wants a mixer tap with a switchable...
Splitty
S
