UHF wiring help | on ElectriciansForums
Discuss UHF wiring help in the Electric Underfloor Heating Wiring area at ElectriciansForums.net
Dorset
Morning all, just after some help with some UFH wiring on my job im doing
Doing an extension which has UFH in the extension with its own UH4, hard wired stats and zone valve (all working and firing as should)
There is an additional loop in the existing house with has its own UH4, one hard wired stat, zone valve (separate location to the UH4) and a pump, I currently have a 3core cable going from the zone valve to the UH4 for my L,N & SW
My questions is that as my SW goes to fire the boiler (orange) how do I stop the pump firing up when an other zone valve is firing up?
^It should do, as it has separate output relays, multiples are designed to be connected together without problems. You need more than 3 cores to the zone valve though. The floor pumps should be connected to the pump terminals in the UH4 and the main pump should run with the boiler.
Do you have some photos of the wiring?
Reply to UHF wiring help in the Electric Underfloor Heating Wiring area at ElectriciansForums.net
As per Davesparks, it would be helpful to see a picture of the valve etc. If the manifold valve referred to is a common or garden motorised...
Unfortunately I don't think you will get an "off the shelf" diagram for the system you are trying to do The Wiser system is very adaptable but it...
T
Indirect (Boiler Fed) Megaflo Doesn't Stop Heating Hi, I noticed yesterday that when my HW is on, that the boiler runs constantly... I even...
techweb
T
Update... I wired up my first heating system today! Thanks to all the help in this thread, (and the initial thread) I was completely prepared...
The 4 pumps are :- 1. boiler to cylinder 2. C/H and UFH circulating pump 3. UFH dedicated pump after manifold 4. DHW circulating pump. (this just...
